NaymzJaymz
Hello. We have a Honda BF100 with a fuel coupling that gushes fuel out when the fuel line bulb is pulsed, even when I'm holding the coupling against the motor. We bought a replacement coupling, and it got even worse. It's a coupling with two "pins", one for gas and the other a locking pin. We've had the boat out twice since we bought it, and it's gotten worse. The engine shuts off for no reason, but when I keep the fuel line pressure tight by ocasionally squeezing the bulb, it runs perfect. After the motor is running the leak slows and then stops. I think it's a early 90's motor with a blue and white paint scheme. Was there some king of gasket present that fell off? I don't think so. To you experienced people this probably seems like the dumbest problem, but this is the first boat we've ever owned. Thanks so much for any help you can give us.--James
