I'm the original owner of a 1984 (I think that's correct) B100L. The actual number on the identification plate is B100L-1600917. From my research I believe this is a 1984. Manual pull start. Little use overall and is in outstanding condition. It's been sitting for several years without use. Carb was not drained completely. I'm trying to get it running again and having issues. It started up on 4th pull but won't idle and won't start unless fully choked. It'll run in neutral with me feathering the throttle but as soon as I let it idle down it dies. Of course if I try to shift it into gear it dies b/c I have to idle it down before shifting it. I'll put it in gear but before I can rev it up it dies. Initially I had fuel spitting out of a port on top of the carb (see pic with yellow circle around port). No expert in this area but knew enough to know that wasn't normal. So I removed the carb and used carb cleaner to clean as much of the carb as I knew how. This is only the third carb I've cleaned so I really didn't know how far to take it apart. I cleaned every port I could see but didn't remove any needles, screws, etc. I was afraid I'd screw it up worse. I put it back on the motor and that solved my problem with fuel spilling out the top port. But it still won't idle and only starts at full choke. Any help on how to solve my issue would be greatly appreciated. It's hard working on this stuff when I'm a newbie but I do enjoy learning about it and there's no other way to learn than to just dig in. Thanks again.
