Honda 90 2006 four stroke.
Deak
I changed the oil and unfortunately knocked the (I believe) low pressure fuel filter and hose off the connection right below the oil filter. I am having difficulty finding where they hook back up. The filter is on one end and has a very short stiff Plastic hose attached while the other end (about 7-8”) from the filter has a tee to hook up hoses. Anyone ca help please?
Hi,
The link below depicts the fuel strainer (item 2). This page is labled.F 8.
Look in lower right and you will see FWOA-F0800B. The F08 part of that is why Honda calls this page F8
The fuel strainer nipple end is referenced to see page E-2 for the connection.
See link below.
The fuel pumps and the 3 way connection you mentioned is lower right.
Note the reference back to page F-8 that depicts the fuel strainer.
Look under the fuel pumps and you see ZWOA-E0200. That's why Honda calls this page E2 in the reference note.
I hope that this makes sense and helps you.
Good luck.
I realize that I might not be completely understanding your problem so I have included another page for you to look at. Item 18 in the link below does resemble a small fuel filter and there are several hoses and connectors.
Sorry if neither of my guesses are correct. Just trying to help.
Thank you
