I have a 2009 Honda 50efi outboard. Last week, after running fine out to our spot, and cranking to return home, it bogged down and cut off. Idle speed is ok but whenever I try to give it gas, it shuts off. It struggles to start back up but does...I tried checking the fuel water separator as well as replaced the gas line from filter to engine since I noticed a small amount do dry rot- thinking it was pulling air into the line...I zip tied the new gas line tight to the engine and the problem is still happening. Any ideas on what to check/ replace? I work on the water and need the skiff back ASAP. Thanks so much for any help-its greatly appreciated,
