Can any one tell me where the safety neutral switch is for the Honda 50?
When I try and start the engine sometime I get no response. If I wiggle the shift it will fire. Sometime I have to push the side button and give it gas and as I pull back while keeping the key engaged it will start. The problem is obviously the neutral switch is not closing properly when the linkage is in neutral. The throttle unit has a plate on it that says there is not neutral switch inside. Honda apparently has the switch in the engine. I see it in the shop manual wiring chart but don't know where it is.
Any thoughts on fixing this problem would be appreciate.
