daz_bradley
Hi Everyone
I am new to the forum and have an issues that's confusing me and the engineer I use!!!
I have a 2003 Honda 225HP Outboard. Recently after having an engineer do some work (change fuel separator) I noticed the Check Engine light was on. The check engine light remains on but no alarm is sounded and it doesn't go into limp mode.
I have plugged in a genuine Honda diagnostics kit and no fault is showing and its showing as engine power available as 100%. The Dr H Diagnostics look to be working well as it shows all past codes and if we pull a sensor out the alarm sounds, it goes into limp mode (50% engine power) and shows a fault.
Does anyone have any ideas what could be causing this check engine light? Ive used the RIB without any issue and there's no fault codes. What could be the issue?
Really appreciate any help and ideas...
