I have one battery just now and also have a selector which is not hooked up yet. The engine is in the up position and I want to lower it. I tried hooking it up yesterday, but now realize that the ignition switch should probably have be in the on position for the tilt motor to work. I thought I had read that it did not need to be on, but I think it must have said the engine does not have to be running to tilt the engine. I would appreciate it if you would explain the hook up for a single and also two batteries when using the switch. I have quite a bit of work to do on the boat, so it will not go in the water this year. Thanks for your time and responding to my post. Bob.Do you have one battery or two? Do you have a battery selector switch?
BTW - the key switch does not need to be in the ON position for the tilt/trim to work, if the engine is wired correctly.
As for wiring up your selector switch, if it's new, instructions will be in or on the container. There are numerous diagrams and instructions on the Internet for hooking them up correctly for whatever setup you have. Just do a search. Start with the website of the switch's manufacturer.
Hi Johnnygjr. Happy boating to you.Happy boating
