I have a problem that began the first time I put boat in water this season. Started and idled fine and would run up to about 4K rpm but would not respond to throttle beyond that. Had local mechanic drain VST, replace all three filters, and pull/check the plugs. Also added some injector cleaner. No improvement at all so called Honda dealer for dock call. Hooked up the computer and told me it was the IAB, air intake bypass valve assembly. Said it was only reading .5v and also stated that there was plenty of fuel pressure to injector rails. Came back and installed the part and now running worse than ever with low speed missing, shaky idle, and can not get much over 2K rpm. Said he was returning today with computer, which he should have had, and will check it out again. Anyone have any thoughts?
