joerockfish
The motor was being serviced f
The motor was being serviced for normal stuff up and lower fluids. Next they replaced the timing belt. After the belt was replaced now we have problems with compression in cylinder 5 and it appears to be a bent exhaust valve. Currently the shop is pulling down the motor to check the head and of course replace the bent valve. Is there anything else that I need to make certain the repair shop checks or should fix? If the valve repair is successful does this repair in any way shorten the life of the motor or make it less reliable? Thanks for your help in advance.
