My My 2004 BF225hp Honda outboard is running a little rough.
A little history; Since I've done lot of trolling and had black soot at the exhaust output, last year, I decided to run with Yamaha Ring Free mix. I did this at end of last season on the day that I hauled the boat for the season. I had run the ring free mix at the dock for 30 minutes, and then decided to run underway. I ran up to ~3,000 RPMs and the motor bogged down and so then I limped back to the ramp at <2000 RPMs, hauled it, did my year end maintenance and prep to deal with it this coming season.
Now, this new season it would not turn over. So I decided to clean up the VST. I replaced all Filters, O-rings etc. I found the fuel line connection from the rail was all crappy and the O-ring deteriorated, the High Pressure pump Filter also had some percentage of blockages (replaced). So I had my smoking guns. Also, I had my fuel injectors sent out to be serviced, diagnostic printout showed 5%-10% blockage and bad spray pattern. All clean now with new filters.
Now I put it all back together, engine started right up. Now its runs but I'll say “a little rough”. While Running Low Idle RPMs, it sometimes does not run consistently steady RPMs. Since I am just in the back yard on Muffs/Hose I did not run it too high on the RPMs for any length of time. When I run 2000 to 3000 RPMs it runs, but you can hear a faint Putt-Putt but still maintaining the higher RPMS. There is no lag when increasing the throttle. I have run with a spare 6 gallon fuel tank therefore bypassing Low Press and water Filters, with no change.
There are No audible or visible errors from my key console, just the slight rough running.
I do have an OBD software tool program; it does show that the engine had a "past" O2 Heater Failure. Still learning how to understand the live data and correlate it to my problem.
In the past I dealt with the fuel rail Mesh/Filter problem which caused the gas pressure to exceed the 41-48 Psi. and it was sending the error code "1". But that has since been corrected and I'm assuming this is the left over fault? I did clear that fault out last year. Maybe the O2 sensor went bad again?
Note 1: The cover if the VST when removed had O-ring with gasket material. When I put back with new O-ring I did not put any gasket material with it because the shop manual did not indicate to do so. Should I have added gasket material?
Note 2: Another observation, the exhaust now is very clear "not smoky". As I understand if its black smoke soot it could be a hint of the O2 Sensor malfunction?
Note 3: The current 02 sensor was installed June 2015, and prior to 2012 had the upgraded exhaust pipes.
Things to do:
Looking for some additional troubleshooting advice, thanks!
Things to do:
- Clear error and see if problem changes or error comes back. Question: Would the old error confuse the ECM and cause this rough situation?
- Test Fuel Pressure again.
- Perform Diagnostic testing of O2 Sensor.
