The gas seem to be fine but I’m going to hook up an auxiliary tank anyway to see what happens. I removed the temperature sensors and heated them with a heat gun and didn’t get an alarm. I have thought about putting a plug in where the temperature sensors go in and run the engine in my drum just to see if it still shuts down. If it doesn’t then I would think the buzzer or lamp is not working. What’s your thoughts on me doing that? I appreciate all of the questions and hope I can get this thing figured out. I kinda feel like its shutting down to protect the engine from overheating. The sensors seem to be pretty dirty or a little build up on them. There is another sensor that looks like a temperature sensor and is bigger than the other two. Not sure what that one is for. I’ll pull it out today and see what it looks like. It kinda looks similar to a cataletic converter sensor. Thanks for your response.No buzzer? No warning lamp? Have you noticed if the green oil lamp is always on, as it should be, when the engine is running?
It sounds a bit like it's going into "guardian mode" to protect the engine but it should also have a warning buzzer and lamp prompt and should restart after the igniton is cycled off and back on to allow for "limp home".
I would be concerned that it might be overheating or oil pressure is getting too low.
Is the fuel fresh and water free?
If you have a portable tank to test with you might try using that with fresh gas in it to see what happens
The no restart untill cooling down some is worrisome.
These engines have issues with the exhaust manifold hoses getting debris trapped in them causing overheat. See items 7 and 8 in the link below;
Loading…
www.boats.net
Sorry, no answers, just questions
