Time4Family
Sorry this may be a long post but I want to include all of the facts.
I have a 20 HP honda electric start on an 11' walker bay.
I have had some issues with the battery being to weak to start the motor but it always pull starts on the second pull. Last week I had the same issue but about 15 minutes into running the buzzer started going off. The oil light was lit (green) and the temperature light was not lit. The water coming from the motor was warm at best, almost cool. I was running at idle or slightly above. The interesting thing to me was that it would buzz with the key on before I tried to start the motor. I was under the impression that the buzzer shouldn't sound below 1400 rpm. Well I continued to run it as the buzzer was varrying in intensity but the motor would rope start and the lights looked good.
A couple of times I would increase the speed and the motor would die almost instantly. I have navigation lights on the dingy and I discovered they were on so I turned them off. As soon as I did the buzzing stopped. (Low battery?) but not 2 minutes later the motor died and would not start. I had to be towed in.
Yesterday I had a friend help me and we found that we had 10.37 volts on the battery cold, 9.9 with the key on and 2 if you tried to crank it. I bought a new battery and then tried again. The motor cranks very fast now but will not fire. I pulled a plug and it had no spark. While we were sitting there looking at it we forgot to turn the key off and I could hear a sizzling sound. When we went looking for the sound we noticed smoke coming from the either the black box on the front of the engine or the wiring connected to it. I didn't leave the key on long enough to see for sure. If you turn the key on you can hear the sizzling sound almost immediately.
Just don't know where to go from here. Could running the engine with a dead battery burn out the CDI?
Rick
Rick
