Last fall (October) after not running my pontoon for several months, I changed the impeller and tested the motor in a garbage can filled with water. It worked great, strong telltale flow, tested for 60 minutes total across a few sessions. When my wife and I took it to the lake it overheated in five minutes. Unfortunately we cannot recall if the telltale had a stream then or not.
I haven’t had it out since last October. Today, I flushed the engine with the nozzle attachment (no shredded parts or plastic came out) and then disassembled the lower portion and put yet another impeller in, even though the one from the fall looked fine. (When I disassembled it the key fell out but unfortunately I didn’t get a chance to see if it was in the right place initially).
I tested the new one similarly today and I’ll in the bucket it works fine. I fear however that under load it will overheat again. It’s a major pain to get it lake-ready, haul it there and then come home when/if it fails.
I’m wondering what else will make it overheat only under load. I can’t mimic it by running it in gear in the bucket because all the water immediately splashes out. Some say this could be a failed thermostat but I believe I’ve heard that this is almost unheard of with this motor.
Any suggestions appreciated on what could be wrong if anything and what to do next! (If there’s a picture attached kindly ignore it as it’s irrelevant and I’m not familiar with how this forum works with those)
