bauxitebill
Boat started and ran fine, did oil change and gear oil change. Went to lake - got constant alarm - engine would not crank, brought home - hooked up battery charger - it signaled battery bad. Replaced battery - as soon attached positive lead - engine started cranking key off.
1. Removed Key switch - still cranks as soon as positive lead is connected.
2. removed wire from main assembly relay to starter - positive lead can be connected - but as soon as you connect wire from main assembly relay - engine cranks.
Starter ? Main Assembly relay or something else ? how do I check ?
