Yes, I have a multimeter. First, let me tell you what happened, took it out for the first time Friday, started second pull, worked fine for an hour, then I stopped to talk to another boater,then I went to leave, on the first pull, it made an offer, but that was it, not a kick after that. I looked at the kill switch, it's a sealed, round, canister type with a very small hole in it, how can I actually check it?Not necessarily. It could be any number of things. The KILL SWITCH suppresses the ignition to stop the engine. If it's activated or shorted, no spark.
There is a coil under the flywheel that powers the ignition. If it goes bad, no spark. Or it could be a broken wire....an unplugged wire or a loose connection in an ignition wire.
Or, it could be the CDI (or powerpack as you say) or the ignition coil itself.
So, you can see that some testing needs to be done to diagnose no spark.
Do you have a wiring diagram or shop manual? Digital multimeter?
