bert kolmel
motor was completely rebuilt and new carb , yet it still backfires throught the carb and rough starting , new plugs, rotor , distib cap and wires any help appreciated
cadorette 1986 holiday 200 has a omc v6 and a merc cobra stern driveAyuh,.... What'cha workin' on,..??
Holiday 200 V-6 don't sound like Any motor ever put in a OMC powered boat...
it is a 4.3 litre engine , i inherited this boat and it sat for many years and has been rebuilt recently dont have any paper work on it other than ownership , where would i find the exact model number for u etcAyuh,.... We're gettin' Closer....
The Boat is irrelevant to yer motor....
OMC used a couple of Very different V-6s, so We need to know Which 1....
'n,....
Mercruiser never, Ever built outdrives for OMC.....
ya did that too the motor was rebuilt from top to bottom as mine sat for many years also , it only has 135 hours on the hull etc, wondering if distibutor is 180 degrees out , not sure is number 1 cylanderLook for a tag behind the engine starboard side just below where the head meets the block.
About your problem, when you run this boat use a external tank of clean fuel hooked straight up to the fuel pump. Clean the filter in the fuel pump and the filter in the fitting that enters the carb.
1986 oem came with points in the dist... you installed a new set ? Wires good. Plugs good ? Hell maybe you gave it a complete tuneup ?
Me i rebuilt my carb. My 86' sat for 8 years before i got it. What carb it have on it ? Maybe a Rochester 2cg maybe ?
Get back to us.
