Help
brokewhilefixin
"okay I've posted twice on
"okay I've posted twice on the same motor.Am i asking wrong??SHould I just take it to a dealer and wait for Oct.when they can look at it??Does anyone know where i could find more info on a 4cyl 50, besides the manual because the two I've ordered may come in oct. when they can look at my boat.Please someone reply just so I know I'm getting through, even if its just to tell me to go dirt biking and forget about boating.
thanks"
Post the results of a compress
Post the results of a compression test and a check to make sure you have spark that will jump a gap of 7/16" or better at each plug.Drive 3 hrs and I can repair it.
thanks for answering compressi
thanks for answering compression 120 give or take a lb or 2 across the board. spark at all 4 . 7/16? this must be just a test? then regap and drive for three hrs got it I'll let u know what happens. thanks again.
"okay Spark cheats to the clos
"okay Spark cheats to the closest point at 1/4 it jumps but 7/16 is a big gap, so the spark is jumping about 1/2 the gap to the side.Not sure what this proves but thats what happens. 120lbs compression give or take a lb or 2 across the board. As for the Three hour tour the skipper Giligan and I had the same results as before.altough after An hour and some minor adjustments to the air screws it is a little smoother but the overall picture at the end of the next two hrs remains the same.ever so hopful that U can help. thanks again"
"almost all problems are fuel
"almost all problems are fuel issues, remove and clean the carbs. Make sure the main jets are clear."
"yea thanks Charles,that would
"yea thanks Charles,that would work for me.The sad news is I believe my reeds are done.Being that their on the crank this motor may sadly be piled in the corner of my shed in hopes that some day I have the time and $$$$ to fix it."
