With help from this forum we were able to diagnose the problem with the motor stuck in neutral, the shift sw. as bad. new sw. was a 3 or 5 wire set up & supposed to come with wiring diagram but did not. This was not a problem as all wires were color coded.
However, after replacing the sw. the motor will not start. Doing tests on the terminal block indicates there is no power to the coils. We do not understand how replacing the sw could affect starting, the motor has always started great.
We put the old sw back in as it started fine with it, but now same result.
We're stumped, looking for any ideas.
