Summary:
Boat trouble after head gasket replacement. It runs, but quickly revs too high and then dies when trying to pull back the throttle.
1989 Maxum I/O with 3.0L Mercruiser GMC engine.
Full Story:
Owned for 13 years. Ran well until I let it set for the last 2 years (with Seafoam in the gas) because life got busy.
New Battery. New Starter. New ignitor coil. Got it running briefly on the lake, but wanting to die. Tweaked idle adjustment. Would run well on earmuffs. Got to the lake. Runs, but instantly dies as soon as I engage the motor (put under load). Replaced plugs and wires. Had hell of a time starting. Burnt through new starter and battery. Replaced both AGAIN! Drained old gas (yes I feel stupid for waiting this long) and replaced with fresh gas and seafoam. Can't get it running. Replaced carburetor. Can't get it running. Checked compression and found cylinders 2 & 3 were very low. Pulled the head off and found gasket was clearly blown between cylinders 2 & 3. Replaced head gasket and valve cover gasket. No other gaskets needed because exhaust and thermostat were removed WITH the head. Upon first attempt, it fired up nicely, but quickly rev'd too loud. I backed it off and it died. At this point, it's tough to get it fired up, but when it does it revs too high and dies when I back it off.
It really feels like something easy an amateur mechanic, like myself would have missed, like cable adjustments, plugs wired incorrectly, etc... Please give me ideas of what to check.
Note: When pulling the head, I didn't move the crankshaft. I also didn't unbolt or adjust the valve rockers because I was able to loosen the head and then pull out the rods. I kept them in order and replaced them the same way the were removed.
This has taken me about 2 months to work through all this. I was ready bite the bullet and take it to a mechanic, but all local guys are booked out for at least 4 weeks. PLEASE help me diagnoses so I can get back on the water!
Full Story:
