el_pescador
Silver Medal Contributor
"Jim,
Regarding manifolds,
"Jim,
Regarding manifolds, you may want to go for center rise.
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-1998-1&returntopag e=80240437.htm
Risers: depending on your exhaust Y-pipe shape, either this
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-1999&returntopage= 80240437.htm
or this
http://www.marineengine.com/parts/part_details.php?pnum=SIE18-1907&returntopage= 80240437.htm
Regarding the fresh water kit, I would not recommend to install it on a block and heads that have been running on salt water.
If you tear apart the engine, I think you should magnaflux heads and block to make sure they are not cracked. If the block is bad, you may consider replacing it with a 351.
I would also stick to carb and not EFI (fewer problems). Make sure you install the goosenecks if they were not installed.
Engine manual: Between Clymer and Seloc, I would get Seloc."
"Jim,
or this
