I am working on an '04 Mercury EFI motor. I've put in days of work and tons of money to get it right so I can sell it.
It starts easy, runs fine, but has a miss at one point throttling up and back down to neutral. If I gradually increased the speed, then it was fine. But if I slammed on the throttle then it sputtered/missed out.
Compressions: 165lbs on all cylinders
Spark: All cylinders are firing nicely
Vapor separator tank is cleaned out and pressure is at 130lbs
Injector heads clean out and all spray strong
Mechanical fuel pump works fine
Could it be the map, throttle control or idle sensors or all?
I have 2 motors and been swapping out and in parts for the past few days. The same problem occurs on both ECM, fuel distributor manifolds and injectors, both VST pump, both mechanic pump, both of everything electronically and mechanically...
I've worked on many EFI and carburated Yamaha 4stroke. But this Merc just doesn't seem to run into any of the common problems with 4strokes that I've known.
So, please help me if you have anything on mind for me or if you have come across this same problem.
I thank you very, very much.
