Docksidemarineservices
Silver Medal Contributor
It is just a different color lenses.Makes me wanna take one apart and see how it works![]()
one bulb. one lighting circuit.
Looking at the switch diagram my guess is the light is just on and off depending on the input. Thinking the different colors is just the lens color is different depending on switch position kinna like fiber optic the just travels thru the toggle? Try just wiring the toggle lights directly to its own fuse in the fuse block that way they illuminat when th master power is on.
Ok i figured it out you could use two diodes per switch but you cannot daisy chan the lights. You woul need to wire all the lights from a common bus bar and put a blocking diode keeping hot from going back to the bar. Thats the night light circuit all lights will be lit. Then put a blocking diode between load and the light on the switch. Any low amp diode will work
