Heat sensor needed!
Paul070
2004 Johnson 115 HP 2 stroke Bombardier J115PLSRC. I need a heat sensor. I can't find the right part number.
If they're no longer available can I disconnect/bypass it?
Is there a substitute?
Can I add one with a gauge directly to the block?
What would a local repair shop do?
Please help, thanks.
Find the part # right here on this page.-----boat engine parts.-----Have you tested your sensor ?-----What is your motor doing / not doing?
I'm not sure what page you refer to for part numbers. And no I didn't test it. It overheated a few weeks ago and went into slow mode. I replaced the impeller and thermostats. Now the HOT light comes on immediately when I turn the key. It starts, pees, and runs fine but stays in slow mode.
