Mikey N.C.
Advanced Contributor
Customer brought in a , found out 1977 20hp mariner. Serial # 653 S 11669
I've got 135 v with dva on gray wire to #2 coil pull start!, orange wire #1 coil primary only 80-100 v , with pull. Gets spark to plug # 2, but not #1 plug wire.
I've reversed coils , still no spark at #1. If I'm wrong please tell me !!! I pulled flywheel and it has old , ignition coils or lighting coils. The grouped together coils under flywheel they're binded together are the 2 red wires for charge, which those wires go to no connection.. At the rear there is same type copper wound coils that are individuals, gray wire from 1 and orange wire from other, screwed together 1 on top of other. Question there's 2 sets of points, 1 for gray wire and other for orange wire. 1 set o points is burnt ( cylinder that's not firing) I called Mercury and have researched to no help at all. Mercury said they will call me back. They couldn't find part # for breaker points. Also I don't have tool to put on crankshaft to set points.
If anyone can shine a lite in the rite direction with breaker points # number and tool # number to set gap. Would be highly appreciated. THANKS
