1989GT150V6
Hi
I have a 1989 150 GT V6 that I recently acquired on the back of a Four Winns 180 Horizon
In general it runs pretty well for a 27 year old engine and I am in the process of slowly repairing/replacing any old or obviously worn parts. Yesterday I thought I would clean and inspect the ignition system and took off the coils and HT leads.
I can now see evidence of what I assume is overheating as some of the coils on the right hand bank (as you look at it from the rear) are 'melted' where they are bolted to the head, the primary wire shrouds are melted in some places and the black paint on the head shows signs of blistering.
I have recently replaced the pressure relief valves as the white plastic inner valves were deformed which I now suspect was caused by the overheating. Also the temperature sensor switch on this bank is deformed (new one ordered).
My question is - what else could have been effected by this overheating that I should be sorting/worried about?
I have checked the compression levels and have readings of 65-75 psi that I hope are low because of my cheap gauge (new better one ordered).
Any help or advice gratefully received.
Phil
Phil
