bulletine
I understand this is not a Crusader question, but you all have great knowledge, this is the best place to ask.
I am replacing a broken plastic thru-hull fitting with a stainless one. On the new fitting there is a screw which I
assume is for grounding. Is it really necessary to ground this one fitting, about a foot above the water line. I have
plenty of #8 AWG, may even have some green left. If I should, then is it better to run it to one of the closer
salt water intake thru-hulls, i.e. salt water washdown is the closet.
Thanks in advance for any advice...
