aaronbloyer
Well it's that time of year again, getting the ole boat ready for the year!! And you know what that means! CRABS! Haha anyway I have a question about my boat motor that I've been working on and I figured that you guys would be a help! I have a 1996 60 hp johnson outboard on a 17.2 ft key west center console which I'm in love with! So today my buddy and I decided to de winterize it and we changed the spark plugs and put some sea foam in the gas tank along with fresh 10 gallons. We also took all 3 carbs off and opened them up and sprayed them out with carb cleaner then used compressed air to get anything we missed. Next we replaced the gaskets on all the carbs, not a total rebuild. When we put everything back together we started it back up and it ran good for a bit then shut off so I thought it just needed gas so I pumped the throttle 4 times and started it back up it ran for about 5-10 minutes with the throttle half way up not in idle. As we put it in idle it stalled out again so I restarted it and put it in neutral to see if I could shift it into gear. When I did it stalled again. So we adjusted the idle knobs on the carbs a few times and nothing seemed to work... If anyone can figure it out or give me some pointers on why it isn't working please let me know! Thanks!
