"Already I have gained much from lurking here. Enough to want to fix the little problems of my '75 70hp rather than ditch it for a more modern one. Thanks guys.
Would be curious to your thoughts on the following-
* Can liberally spraying your o/b with CRC cause problems, or is it recommended?
* What do you guys have in your spares kit onboard? (Such as...Plugs,leads,coil,powerpack,prop,splitpins.......)
* Maintenance ritual after each outing.(Fresh water flush,motor checks/cleaning)
Cheers,
& tight lines ~"
Cheers,
& tight lines ~"
