baxter1829
I noticed my fuel gauge did not work when I put my boat in the water and started it up this spring. (2005 22 foot Aqua Patio with 90 hp Yamaha). Gauge on top of the tank works fine and shows tank is half full. The analog gauge is on the console. When I turned the ignition to the "on" position all gauges activate but the fuel gauge needle does move a bit but doesn't go past the "E" mark. Removed the panel and popped out the gauge to try tapping but no go. Then I removed wiring from the back stupidly forgetting to turn off battery switch. I must've touched something causing a short because when I connected everything back up none of my instruments will work. (Grrr). Now I have 2 problems (one of my own making). There are circuit breakers on the console beside the switches for Acc, Radio, lights but none seem to be tripped. I believe I've blown a fuse somewhere but have been unable to locate it. Any help would be much appreciated!
