Something strange is happening causing virtually all of my gauges to read wrong.
I have a Sea Ray 200 CC 1989, and there is something strange in the mix.
The voltage pins to the right + 18v, and I have confirmed this is not accurate when running with a volt meter.
The Trim gauge reads all the way to the left. Proper trim is the first line on the left when on a plane.
The RPM gauge intermittently reads incorrectly, and shows a higher RPM than what I am actually running.
The temp gauge is reading high as well. I have confirmed temp with an IR thermometer, and tried replacing the temp gauge. The new temp gauge also shows a high reading.
The speedometer also reads wrong, but I dont expect much from that one.
I would really like correct temp and voltage.
What gives?!!
Might it be a grounding issue?
What gives?!!
