long time OMC guy but the wife got the bug for a new(er) boat, so went over to the dark side. Bought a very clean dealer serviced 2007 Bayliner with a 4.3 (GM) Mercruser/Alpha1 (2bbl carb) with the vaunted TKS. So last weekend the kids are water skiing, tubing and having a great time. Boat is working fine, suddenly dies. Tow it back to our dock and spend the next 5-6 hours tracing with a multimeter. Finally find a 15amp mini fuse buried in the harness behind the distributor. Ok, change the fuse start the engine, boat starts, all gauges normal, runs good for 2-3 minutes, fuse blows. The red w/ purple stripe wire from the fuse runs into the harness and ends up at the ignition switch. I'm guessing that there is a device ( sensor, switch, relay, etc.) somewhere between the fuse and ignition switch that has crapped out, but I can't find a wiring diagram that shows where the red/purple goes after leaving the fuse, and I'm reluctant to tear apart the wire looms and the wrap to find where the wire goes. (not to mention trying to cram my fat a** into the space behind the engine)
So anyone have any thoughts???
