Some of you guys have been on this journey which feels like forever now. A few years ago I bought a pontoon with a Honda BF50A pre-1997 on it. Two years ago I had to have the carbs rebuilt and 4 trips to the shop and back we finally figured that out.
So this year I am redoing the water pump because it's not peeing and replacing the thermostat that hasn't been replaced since I have had it. I also am doing the lower unit gear lube change and oil change.
Since I have had the motor there has always been a leak that I have kind of ignored. Every time I come to the boat or run it the water around the boat changed colors. It looks to me like there is a small fuel leak somewhere coming from the inside the cover and going into the water. I hadn't run the motor in a couple of weeks and drained the carbs to winterize it and went to check on the boat today and there was the colorful glaze over the water. Do you guys have any tips on where to look?
Any other tips on what should be changed out? I have to pump the bulb every time I get in the boat, and idle really high to get it going. I was thinking of throwing a new fuel pump in there? Is that worth it? Thanks! Also just ordered the shop manual.
