wtaddington
I have a 1999 Force 120 that has a single cylinder (Number 1) not firing. I have replaced the plugs and wires. I swapped the 1 and 2 coils and the problem does NOT follow. I checked continuity on all wires from the trigger to the coils. All are good. I checked V on each wire to the coils while running and they all match to each other. I am not sure what the trigger V should be but on a Multimeter(Average) it reads between .7V and .9V. I imagine with an oscilloscope that V is running up and down. Not sure what the trigger value is. I also do not know what should be reading from the kill system black with yellow tracer. It seemed to be battery voltage. I actually replaced the trigger despite the measurements and it did not help. Any suggestions on where to go with it.
