Hi
I just repowered with twin honda 225s. Picking it up next week..
I have a bad back and have trouble bending down to reach the flush port. On my old engines, I attached a 3' hose to the flush attachments, with a shut off valve / quick disconnect on the other end which was attached to the railing on my transom. Made it simple to flush. When it was disconnected from the fresh water hose, I shut off the valve.
1. Is there any problem doing this? Wouldn't want to hurt my new engines.
2. I would like to make it look nicer. I am thinking maybe run the hoses through the transom and connect to a quick disconnect on the gunwale. Could I get away with one disconnect and put a Y on it to supply both engine at the same time? (I have good water pressure)? Or should I have a valve that can direct the water to one or the other or closed? Is it important that it closes off when not in use?
BTW the boat is a worldcat 27te
thanks
thanks
