The 2144 is going to be the fault code... The 6 (in your case) is the fault type code number...
Universal Failure Condition... Description...
| 2144 | Engine misfire | 6 | Faulted | This is for both cylinder banks (all cylinders). |
Number 6 =
Faulted = The device, hardware, a calculation, or a process has failed a rationality check or has detected a fault.
So in your case it is not cylinder number 6....All the cylinders are affected.
You'll want to start off with a new cap and rotor as that is the most suspected issues with this design distributor...Looks good and actual good are 2 different things for this cap... Also be sure the cap and rotor are seated correctly and the hold down screws / threads are not damaged as the housing is plastic.... Next try new spark plugs... Has any service work been done recently? or is this all of a sudden?.. Do you hear / notice a misfire in the engine?...< Meaning possibly fake...
This code has come up online a few times when searched so the following are of some other thoughts but please know one is for a 4 cylinder, and it was suggested cylinder number 4 is the issue but that shouldn't be the case as the code is for all cylinders according to a service manual like noted above....If you can't fix it with a tune up and the engine internals are good, then you may need to reach out to Mercruiser to see of you need an update in the PCM by a service dealer like mentioned in the sea ray thread below.
My 2011 350 MAGs love to kick out the dreaded VesselView error code: Engine Mis-Fire. This is a code that can only be reset with the highly coveted MerCruiser tech software. This started at the beginning of the season (May 1). The boat had 95 hours on it when I took possession, and the first...
clubsearay.com
If you have questions on your Mercury MerCruiser sterndrive or inboard, contact us directly. Please note that a serial number is required.
www.mercurymarine.com
Also there's this,
