I have a '94 Mercury 60 hp outboard. Took it to the lake yesterday and a couple of minutes after starting, (still on trailer) the alarm goes off. I immediately stop engine and check motor temp by placing hand on head. It is cool. so I check thermostat which is O.K. The pee tube is working fine. I disconnect the lead from the temp sensor in the head and the constant alarm stops. This was located at a pig tail connector in the engine compartment. Anyhow, I used the outboard rest of day without any issues checking the engine temp occasionally. My first question is the motor sensor supposed to be an open or a closed circuit. Beyond that, where do I go to further troubleshoot this problem. I realize the need to fix this issue.
