Looking for Chris at Dockside Marine- the Merc Master's advice please:
2001 Merc EFI has a rebuilt block done by some place in the East. New ECM, Injectors are cleaned and calibrated, new coils, replaced mechanical fuel pump, serviced VST, all and all done by certified Merc. It only starts and stay running with advanced cold start throttle. Cam roller and all lined up well, but does not stay running at idle position. Smoked like hell and I had converted its system to 50:1 premixed. Still smokes like a white clound. Spark plugs are all wet, but no water bubbles. Could it have a bad reed? Or could it have a crack head? Compression 124psi on all 6, spark present thru timing light. I am not certified and don't want to redo a certified's rebuild job. But I've done thousands of successful rebuilds for this motor. Please once again point me to the correct direction as of where to start to save this baby Merc. After I converted to premixed, I had it idle for 10min and blast down the river for 15min, but again it shuts off at low idle and can only start up with advanced cold start throttle! If I waited a while then the rpm automatically increased itself, only then I can quickly move to neutral, slam into gears and come in. Kept floating down the stream quite far!
Thanks a bunch and happy holiday.
