I have resealed the fuel enrichment solenoid(leaking externally), repaced the air intake gaskets(distorted) replaced plugs, checked comp.( 90 psi. all 4)and ran with fresh fuel both through vro sys. (ck'ed oil reservoir tank for contamination) and mixed fuel blocking oil supply line. Ran about 4 gals. mixed fuel through the motor to make sure all residual oil inj. oil was purged. Still smokes heavily (grey) and doesn't want to run at low rpm (1/4 throttle and below). What else should I do. Is 90 psi. comp. enough to burn efficiently?
