Evinrude90
Hello expert...I have been struggling to figure this issue out for a while now, and can't seem to get a good lead on it.
The issues: My 1988 Evinrude 90hp throws an alarm (buzzer) for low oil flow but only at very low load and idle. No issues at mid to high load/idle. It is a beep that comes on for 2 seconds and off for 2 seconds, with increasing frequency as the RPM's go up.
I have done a few test, and it seems like the VRO oil pump work fine. Last night I filled a 12" long clear hose (3/8" diameter) with oil, and connected it to the oil inlet on the VRO pump. The engine seems to be pulling oil out from the clear hoes, as it is obvious that the level is dropping.
The above procedure was found here: http://www.boatpartstore.com/vro.asp
Although I was not sure what they mean by "monitor the pump cycles by using a fuel pressure gauge or by putting light finger pressure on the outlet hose."
Not sure what they mean by "put light finger pressure on outlet hose". What outlet hose?
I have taken the oil reservoir out, and pulled the entire pick-up out. The screen is nice and clean. The oil priming bulb is hard when everything is connected to the engine while it is running.
Any input would be greatly appreciated.
