L
loopie11
Guest
I have a 87 evinrude 200 loope
I have a 87 evinrude 200 looper that the lower stbd and port bores did not completely clean up. It already has .030 oversise pistons installed and was honed to 3.533(what is the max bore size for a .030 piston). Are the areas that did not clean up critical areas? They are at the very top of the cylinder (the lower ring will not contact it) and just above the intake slots in the bore. You cannot feel a diference in height with you fingernail. I'm trying to go the cheapest route. I will attach photos if possible.
