Hi guys, I am experiencing a tach problem - its not working, neither is another replacement tach. It stopped working after I changed to a NEW stator and a NEW powerpack. All connections are fine and the engine works great (Evinrude 130HP V4 1995 2-stroke). I read in this forum somewhere that you can lift the powerpack, remove the grey tach sender wire from its standard connection and attach it to the the yellow-red wire on the connections strip. If the tach then works, then that would mean that the rectifier-regulator is bad. Does this also apply to my engine, which does NOT have a watercooled rectifier-regulator (I think mine is a 9 AMP one)? And if this trick works, does it necessarily mean that the rectifier-regulator is bad? Hard to imagine, as everything works perfectly, also the charging system. Input much appreciated!
