I have a 4.3L throttle body injected Mercruiser (s/n M093527), we just installed a brand new long block. Ever since installation the boat runs good at idle and on muffs but under load it will not go over 2000rpm. We used some existing parts off the old engine like intake, distributor, coil, things like that but from that old engine everything was fine and working 100%. In between when i blew the first engine....... till now, the boat has sat for 2 years. Clearly whatever fuel that was in it was old but i did not have much left in it.
Before start up i filled the boat with a mid grade fuel. So fuel should be good enough in my mind to get me over 2000rpm. So far we have changed the electronic ignition, i still had the old factory green chip ignition....... and am now running a new Thunderbolt iv. I purchased a new distributor cap, a brand new coil, a brand new fuel line that was kinked and in which i thought was not allowing the proper amount of fuel to go WOT. Right now im at a loss!? I don't know what to do or change or look at next!?! Basically 96% of the parts on this engine are brand new?? and My prop i didn't change, i have a high 5 and its always worked! I also just replaced my fuel filter just to rule one more thing as well, so im not sure what to look at next??
