Several years ago I was at shasta lake when I began to hear a "tick" coming from the engine. I stopped running the boat for the weekend, and drove it home. When I pulled the intake manifold I found a lifter with the plunger lodged sideways. So with a little extra money in the bank and a good excuse, I did a full Cam, lifter timing chain, and springs. Bolted it all back together and BAM, the freaking tick was STILL THERE.
Now I removed the cylinder head again and found about a tablespoon of oil on top of the piston and a shiny mark that looks like the exhaust valve is kissing the piston. The mark is uniform on the flat and raised portion on the left. The engine is a new rebuild from a mass rebuild internet place. It was purchased as a "Marine Engine" (Father in-law purchased it before we got married) It has less than 15 hours on it.
I have not run the engine past the break in period of the new cam.
The sound is definatly coming from the exhaust valve.
Can a bad guide cause this problem??
Does anyone know of the proper piston to deck clearance??
An help is appriciated before I start spending money
