Joshnovak1
My father in law had the boat running for half the summer about 3 years ago, and then one time out he put it in the water and it would stall out every time he tried to throttle it up. He stored it for 3 years and now I am trying to fix it as he gave it to us as a present.
We took it out of storage after 3 years and drained all the fuel out of it. I put fresh fuel in it, injector cleaner, and a new fuel filter on it. It took about 15 - 20 attempts to start it, but then ran for about 5 minutes before stalling out. I changed the TPS sensor and it did nothing. We then changed the fuel pressure regulator, and now it runs like a champ on idle. Still takes 5 - 10 time to try to start it. We've had it running 3 times now on idle for about 15 minutes each in the driveway with mufs on it. Every time I go to throttle it up, the RPMs raise a little and then it wants to stall out on me. I have to quickly throw it back into neutral to prevent it from stalling. From the research I have done it sounds like it could be a fuel pump. It's the 1994 OMC Cobra 5.8L 351 EFI so it has two fuel pumps. One Low pressure in the front, and one High pressure on the top rear side of the engine. When I turn the key over to prime the pumps the rear one whines very loudly and if I put my hand on it, I can feel a lot of "action" in it. The front one makes no whine but I can still feel something happening in it. The rear high pressure one also whines quite loud the whole time the engine is on and idling.
My question in the end, is how do I know which fuel pump is bad? Is the High pressure one whining because it is not getting fuel and the low pressure one is bad, or does the whining mean it is bad and needs to be replaced? Or is there something else I am completely overlooking here?
Any help would be great guys. Thanks!!!
