Engine ground cable for BF225 part no
b225
What is part no for Engine ground cable? Is it part of some harness cable set? Need is to renew just main ground cable fro below engine:
BF225A 2003
BAGJ-100342x
Also where to find documents showing exact locations of Main Grounding Points on the Honda BF225 Outboard:
1. Main Engine Block Ground (near the starter motor)
2. ECU Ground Point on the Engine Frame
3. Ground Junction in the Wiring Harness
4. Dashboard Ground
Also what is part no for CKP sensor for
BF225A 2003
BAGJ-100342x
Is it as my consultant says:
Correct CKP Sensor Part Number:
30300‑ZY3‑013
Curious also of steps to replace it as my consultant says:
Why this job is doable for a DIY person
  • The CKP sensor is held by two small bolts
  • The connector is a simple plug‑and‑click
  • No timing adjustments or calibration needed
  • No fluids to drain
  • No special Honda tools required
It’s basically:
  1. Access the sensor
  2. Unplug it
  3. Remove two bolts
  4. Install the new one
  5. Plug it back in
That’s it.
I assume page 2-33 of Honda-Outboard-service-workshop-and-repair-BF175A-BF200A-BF2 is best available for ckp location?
4. Dashboard Ground
That must be no 1
