crazzinezz
Weird problem i'm having cant figure this out.
1990 4.3L TB 4, ALPHA 1 4 Barrel carb.
while in WOT boat is a bit lazy, it will get on plane but not as fast. Now imagine tilt / trim is ALL THE WAY DOWN if i push tilt up or down or trim up or down as soon as that hyraulic pump kicks in the boat takes off, its like instant turbo boost, if i let go of the switch its back to lazy mode again.
whats been done : plugs, wires, cap + rotor, ign coil, fuel pump, filter, gas tank drained and cleaned, new edelbrock 1409 4 barrel carb, oil change, impeller, 14.5 x 19 prop, oh and a new battery.
any suggestions and or help would be appreciated
thanks
thanks
