Robert List
Hey all, I'm new to this forum, have a 1983 25 hp long shaft, just bought it, replaced the power pack to get it running, runs dang good with the remaining old parts on it, plugs, coils, etc. Plan on replacing pump impeller, plugs, carb kit as the weeks stretch on. While running it out on the river to just see how it does, and and what I need to address, I noticed that flat out, it's great... but if I hit rough water, and start slamming hard into waves, the motor will "die" on every slam, and comeback good between them...after about 15 hits, it will stall, but start right up again and run great...... this is fairly rapid, normal rough water type thing..... is it possible the needle in the carb is getting stuck on every bounce, cutting fuel for a split second? runs steady and good all other times, only runs bad when slammed hard. Thanx, y'all
