Reel Turner
I have two Battery's with a Perko Battery switch. The problem I am having is that when singled out#1 starting battery will charge at 13.2volts while running and #2 battery singled out or on the "all" setting flucuates between 11.7 and 12.1 volts. with all load wires disco'd Both Batts read 12.8volts with engine off. I have 14.2 volts at the back of the alternator and from there the feed wire goes thru a noise filter and I lose .4 volts reading 13.8 at the output wire of the noise filter. I have rechecked battery connections and untaped the harness figuring a short between two wires. neither seems to be the case. Anyone have any ideas for me as where to look next? If you need more info on something let me know. I need help.
Thank You Joe
Thank You Joe
