Dave
I have a 250 HP 3.0 -1998 Mercury outboard, fuel injected with less than 400 hrs. run time. Good spark, fuel up to the injector unit but will not start.
I do get the engine to fire up but only for a few seconds at a time. Any ideas?
Thank You
Fuel pressure test port....should be 35psi or higher, if not you have: A) No fuel getting into VST tank(float) B) fuel pump issue C) bad pressure regulator
