Hi, I am have trouble calibrating my engine trim and the gauge on the dash. The sensor appears to be working, in that as you manually move the sensor arm the gauge moves correspondingly. But when I lower the motor the gauge needle goes all the way to the bottom upon contact with the motor body. The instructions I found online said to put s pin in the #3 hole, lower the motor till it makes contact and the gauge shoud read in the middle. if not adjust the sensor position.
Non of this helps. not sure if it"s the gauge, sensor or maybe a solenoid. could sure use some help.
